What are you looking for (Speakers, Subwoofer or Both)? Both: 5.1 Dolby Digital System
Primary Use: 10% Music, 90% TV & Movies
Desired Configuration: 5.1
Room Size: 18x20
Is the room open to other areas of your home: No (It is Basement setup)
Do you already have an AV receiver or amplifier? No
What's your budget (low to high): 350 - 400$
Any special requirements (Wife Acceptance)? Nope
I have couple of options:
Option 1: Total Cost - 388$
> Logitech Z906 5.1 Surround Sound Speaker - 388$ (*No receiver needed. )
Option 2:
> Polk Audio TL1600 5.1 Compact Surround Sound Home Theater System with Powered Subwoofer - 179$
> Receiver: Needed: which receiver can go with it and cost?
Option 3: Total Cost - 300$
**Used system
> Polk Audio 5.1 RM6750 speakers
> Denon AVR-1612 receiver
Option 4:
**Used System
> Bose acoustimass 10 - 250$
Room Size: 18x20
Option 2:
**Used system
Option 4:
**Used System
