MichaelAngelo
- Oct 22, 2002
Help please with a n00b question. What kind of increase in apparent volume can I expect from stuffing a sealed enclosure? I'm using the cheap Wal-Mart stuff, poly-fill. One enclosure is 19cuft, I used 15lbs stuffing (.5-1.5 lbs per cu ft, right?). The other enclosure is about 23cuft, and theres about 20lbs of stuffing in it.
Also,,,
Does the Vd of a passive radiator get "added" to the Vd of the driver in a PR system?
Thanks for any help.
Mike
Also,,,
Mike
