Hi all,
I'm moving and need some pointers on a couple of different ideas I have on a speaker upgrade.
Situation:
I currently live in an apartment with my setup in my bedroom. I'm moving to a new, bigger apartment (more like a town home, I have both up and downstairs). I'm an electronics nut and love good quality components; however, I don't have the budget for big dollar items, so I'm seeking the best quality for the best price. I'm willing to spend descent money as long as it's well worth the extra over a less expensive item. Replacing "less expensive" items a year or two down the road leads to better equipment being even more expensive...
Current setup:
Marantz NR1403 5.1 Receiver
MartinLogan Dymo 500 10" Sub
5 Hand-Me-Down Bose Satellite Speakers (I don't know the exact model, they're the ones that swivel)
Epson Home Cinema 3020 Projector
EliteScreens 84" 16:9 retractable screen (probably upgrading to a 92" or 100" fixed screen)
Since I'm moving I figure it might be a good time to dump those Bose speakers. That's been on my wishlist for a while. All the other component I've got I'm pretty happy with. The receiver is 5 months old, as is the projector. I had to upgrade my receiver when I bought the projector in order to use the 3D Blu-Ray features. The sub is only about a year and a half old.
The new room will be 16.5' X 11.75'.
I'm kind of stuck between two different options, and could use some help. I'm leaning toward the Yamaha NS line of speakers. I'm not totally stuck on them if someone recommends something in a similar price range that would be better... My thoughts here are as follows:
Option 1:
4 of the NS-333 and a NS-C444
I could mount these on the wall next to my screen (under in the case of the center). I'm sure this would be a vast upgrade from my Bose, and I'm sure the sub would do a great job of picking up where they start losing on the low end. However, this leads me to option 2.
Option 2:
2 NS-777, 2 NS-333 and a NS-C444
I think I can fit a couple of the floor standing speakers. I have a light switch on the right side, but I might be able to fit it under the light switch. I need to go back over to the apartment with a tape measure and see how high off the ground the switch is. Assuming it's a standard 48" to the top of the plate I *should* fit. Assuming it does, would this be a worthwhile expense over the bookshelf speakers? Would I need my sub still, or with it be way overkill?
I'm open to any other suggestions or thoughts. I look forward to hearing what you guys have to say.
Thanks!
Situation:
Current setup:
Option 1:
Option 2:
Thanks!
