Jon Van Dalen
- Dec 8, 1999
Well, I've been trying to narrow down my upgrade choices, but I keep hitting dead-ends. So, I hope some of you can offer some sound advice.
I now have:
Onkyo TX-DS474 receiver (55 wpc)
Energy take2 mains
Energy Take1 Center
Energy Encore sub
The problems are that I need surrounds and I need to plug that gap between the sub and speakers. The encore sub is great but doesn't go very high and the take2's dont go low at all, so there's a large gap in AVIA calibration. If I upgrade the mains and center and move the take2's tot he rear, this should solve the problem.
The limitations are these... fairly tight budget... I don't want to spend more than about $400 or so total. Also, I live in a small space with a small TV (20" flat).
So, the speakers I've come up with that would be improvements are the HTD level 3 and klipsch sb-1's. Please add to this list.
I chose those speakers because they extend lower than the take2's and because they have a good reputation.
Unfortunately, I see fairly major problems with the HTD's... one, the center channel is enourmous and my TV is probably too small to support it. 2, my receiver only puts out 55wpc, so I'd like a very high efficiency speaker (klipsch) 3, I live in a small room and move back home each summer by car, so large heavy speakers are a bit troublesome.
With the sb-1's... well they seem fine but i've heard the horn tweeter can get tiring to listen to. Also the matching center is more expensive.
Please, flood me with ideas! Or if you have a whole other suggestion, let that rip.
Jon
I now have:
Energy take2 mains
Energy Take1 Center
Energy Encore sub
Jon
