john_q
- Jun 5, 2004
Hi to everyone here.... I'm gathering up info and most importantly, suggestions for a completely DIY 5.1 speaker setup for a basement that is going to (eventually) be turned into a HT/rec room situation.
So where do I start with my questions? This is the sort of thing where I think I know what I want, but have some questions I haven't seen many answers to in my browsing.
So here goes with some facts about the planned environment. The room will be 24' x 13' when finished, and has 7' ceilings currently (though some will be lost once a ceiling is put in place). The reciever that will be running the speakers, right now at least, is a Sony STR-V444ES. In the future, I'd consider upgrading, or just getting a 5.1 power amp and use the Sony as a pre-amp only.
My initial considerations for speakers hasn't even gotten to the "which brand?" stage yet... but here are my initial ideas:
Main fronts: Sealed towers, 2 8" drivers, 1 4", 1 ribbon tweeter per side. This room will be used for music listening as well as movie viewing, so I'd like to have an option of front's that can be run full range reasonably without demanding a subwoofers help.
Center: Sealed MTM configuration
Rears: Sealed 6" and ribbon tweeter bookshelf setup
Sub: Sealed 15" Titanic Mk III with a PE 500 watt plate amplifier, crossed over at something like 60-70hz
I'm pretty set on the idea of sealed cabinets for everything... limitations on cabinet size is not an issue for this project, and I enjoy quick accurate bass that is not overbearing or "saturating".
My questions however:
-is all this "too much" for the size of this room?
-crossover options seem fairly daunting to me... I see a lot of people designing thier own crossovers, so what am I losing out on buying an already built 2 or 3 way crossover from PE, for example?
-what else do I have to think about aside from matching the crossover up with the posted frequency response of each driver?
Any advice would be extremely helpful... and of course, thanks in advance
