Hey everybody,
I have either a finicky computer or a finicky CD drive, I don’t know which. Okay, I know this computer leaves a lot to be desired – just not as certain about the CD drives.
What the deal is, the drive that came with the computer is kinda cheap, and it doesn’t do a good job burning CDs for music playback. However it has no problem playing back any music CDs I feed it.
In the interest of burning some music discs, I installed a Yamaha CD drive a while back, and now I have just the opposite problem! Burns great music CDs, but when I try to load a music CD – either one off-the-shelf the store or one that’s been burned on a computer – half the time it can’t read it. (I’m certain it’s this POS computer – I’ve tried two different Yamaha drives and had the same thing.)
I guess you know where this is going. What I’d like to do is use both drives, one for play-back and one for burning.
So – what’s the procedure for doing this? I know about the master/slave settings on the drives, but what configuring would have to be done in order for the computer to recognize both of them and know what their intended function is?
Is there a step-by-step site someone can direct me to?
By the way, I don’t ever intend to burn directly from one drive to another, if that helps, so I’m not worried about snyc problems.
Wayne A. Pflughaupt
Wayne A. Pflughaupt
