I have a issue triggering my older Furman Powerports from my Emotiva Equipment. All of the Emotiva gear has input and output triggers, and the XMC-1 Processor trigger outputs (4 of them) are used to trigger all of the amps. Works great. However, they will not trigger the Furman Power Ports, which have a hard wire "12v and Remote" connection strip for trigger input. I measured the trigger output of the Emotiva Processor at 11.8 V DC and ~300Ma. The Emotiva gear does not have any switched 120V outlets on the back which could be used as a solution in conjunction with available switching relays. Any suggestions?
