Drew Stanton
Grip
- Jul 31, 2001
Okay my mom just purchased this TV. At first I hooked up the DVD player w/component video to the TV w/the normal red,blue, and green holes on the back of the TV. The picture was all blue and I was baffled. After that, I tried hooking up my PS2 w/the component video. Now the picture was green colored. So we tried one last DVD player and it ended up being blue, just like the first one.
After doing some research I finally found out that the "Color Stream" option was only for "Color Stream" component video Toshiba DVD Players. If I wanted to take advantage of that, you needed a Toshiba Color Stream DVD player. This is what I have understood that is.
Now I looked in the manual and it only showed how to hook up the DVD player w/compnent video and a VCR, nothing about JUST the DVD player w/component video. Also, in the manual, they sure make "Color Stream" the same thing as Component video, but in actuality from what I have been haring, and it not working for me, I don't think it is. But anyways, I tried hooking up the DVD player and VCR like they said to in the manual in order to get the "Color Stream" playback w/the component video. In order to do this, you hook the component cables to the Color Stream inputs on the TV, then you hook up the normal yellow video out on the DVD player to the video in on the VCR, then the VCR video out to the TV Video 1 input. You then put it on Video 1 input and it should work. I did this w/out the sound. It is pretty complicated for just trying to get the component video playback. Now after I did all this, and put it on video 1, it was finally wokring ... with one problem....
Now comes in the problem of Macrovision. I had the DVD playing, but now macrovision messes the picture all up. Is there ANYWAY at ALL to get the component video to work straight up like any component video on a normal TV? I have component video on my Sony Wega 27", and I just plug in the cables and go to Video 4 and it works fine. Why would Toshiba make you *NEED* a color stream type dvd player? Am I missing something, or is there just a special way to hook up component video to the Toshiba TV? Please help! Thanks.
-Drew
-Drew
