Stephen Gladwin
- May 19, 2005
Well, I've settled into my new 5.1 setup for a while now and I like it very much, but it's not quite perfect yet. I have a less-than-optimal design for my HT room, especially where my surrounds are concerned. It seems the general consensus for surround speaker placement is high (about 5-6 feet above listening level), to the side, and 2-3 feet behind the listener. Unfortunately, I have vaulted ceilings, and the highest I can put my speakers is about 6 inches above listening level. Currently I also have the speakers placed directly parallel with my listening level. If I can't put the speakers higher (they are JBL E10s and can't be ceiling mounted), would it make that much of a difference acoustically to remount them further back, like another 2-3 feet? Perhaps I could buy some ceiling brackets? If I put them on ceiling brackets, they would be hanging off the sloped ceiling: would this cancel out the surround sound accoustically?
**Also: Would playing around with the distance settings on my Denon receiver accomplish a more spacious surround sound? Thanks!
