ScottBRA
Grip
- Jun 22, 2004
Posted: Mon Jun 21, 2004 10:14 pm Post subject: Just STarting - New HT --- HELP
I just got the go ahead to put a HT in my new house. The only room that I can use is the basement. I have some problems, but it is what it is and I see from other posts that people here really know there stuff. The basement will not be 100% theter. Half of the room will be kept as a gym (that was the deal my wife made). The room already had surround sound from prior owner and a built in that held a TV, I will keep the sytem on the same wall. The room is 16'6" wide in total, BUT I can only use 9'3" which is where there is a pole from floor to ceiling. Total length is 23 feet (the pole is 11'6" from the front of the room). In other words, I can use the full 23" in length, but the width is limited to the 9'3" because the pole will block view no matter where seats are. My ceiling is low, only 6'8". I really want a few things and need some help on how to do it:
- I am planning on getting 2 rows of berkline or comparable seat, placed somewhere????
- I am thinking of getting the X1 projector, thoughts?
- I am thinking of getting a screen that pulls up from floor with the black on bottom, my thinking here is tht a pull down from top will not fully cover the eiting TV which I plan to leave there, thoughts??
- Sound system - Not touching equipment for now. Back wall has 2 speakers, and front has 2. Subwoofer in front. I will add one for the front.
- I plan to use a riser for the back row, I was thinking 8 inches??
-Does th TV that projector wors of matter? I am a bit confused on this one. DOes projector plug into TV, Cable, or Surround sound?
Thanks for any help. I am quite excited to get this started.
