Speaker Hum from Cable Ground Loop (1 Viewer)
Robert Ross
I currently get speaker hum whenever I connect both my sub and my cable service. As of right now I've just been d/c one when I use the other, but I'd like to get this fixed. Any idea how to get rid of this?
Bill_Mis
I connected all of my plugs from amp, receivers, subs to the same power strip and it solved my problem. Mine was caused by cable but the amp was on a different power strip than everything else and so plugging it into the main strip solved my problem.
Robert Ross
John: Thanks for the link, I remember seeing that site a while back ago, but couldn't remember where. I ordered the part they reccomended and hope it works.
Bill: The only thing that isn't connected to the same plug-in is my sub, which is one of the items causing the hum, so that could work, but with the placement of my sub, it's just not really feasible (too far of a distance).
John Garcia
NorCal
Good luck :) I ended up calling my cable company and they eventually came out and fixed my problem. I used a cheap isolation transformer to decouple the cable in the meantime and it worked.
Nielmb
