Speaker Buzz (1 Viewer)
Status
Not open for further replies.
Russac
Russ
Hello!
New Member here and not sure the best place to post this question.
I’ve recently swapped out an Onkyo TX-NR1010 AVR in my 7.2 home theatre system to a Marantz SR7012. After hookup and calibration I’m hearing audible (and irritating) buzz through all 7 speakers. I went though the process of disconnecting inputs one by one to determine th source and I found that the buzz stops when I disconnect the two rca connections from the receivers pre subwoofer outs. The two sub lines run from the AVR to a Bheringer Feedback Destroyer Pro/EQ and then to a Bheringer EuroPower 4000 amp.
Any thoughts on how to reslve the speaker buzz as the two Danley DTS subs are critical to my setup. I didn’t have this issue with the prior AVR.
Status
nicos18
