Sony STR_DE935 (1 Viewer)
Dave Nibeck
A friend is having trouble with this receiver. He has lost center channel. Trying to explain to check center set up to make sure it did not accidently get switched to phanton. He does not know how to check.
Any familiar with this unit and can quickly summarize were the setup if found?
Thanks.
Dave Kalloch
Should be a SETUP button on the front of the receiver. Push SETUP then use the Left/right buttons to switch through the options.Use the JOG DIAL under the left/right buttons to change settings. You should find it in there.
Sunday Billy
