Takosan
- Sep 1, 2000
Greetings!
Is there an AVR that can simultaneously output to optical regardless of what source is used?
Some AVRs I've looked say "assignable" but it seems that I need to configure to "a" source instead of the AVR always simultaneously outputting to optical. I also didn't know if I'm interpretting the "assignable" the right way. When it doesnt' say assignable, the optical jack seems to be aligned with "a" source on the back of the AVR hinting at that source is the only one the optical is connected to.
The reason I would like an AVR that has simultaneous optical out is because I have a little device that transmits the out to my cocklear implant with affecting the volume my family listens at. I don't know if this matters but the AVR will be driving B&W 603s2, LCR s2, 602 s2, & SVS-1000 in 5.1 setup. I think the fronts are rated upto 125W. I've been through SR-7000 and now 510BT. Want to keep the budget under $500. The 510BT doesn't seem to do simultaneous optical out from any source as I can only use my device hooked directly to a source device ... my son's PS4 to play DVD/BD; I connect my optical device to the PS4's optical jack, connect PS4's HDMI to 510BT, & set PS4 explicitly to simultaenously out to optical.
Thank you.
Takosan
Thank you.
Takosan
