russell>b
- Jan 27, 2004
Ok .. I have searched and done lots of reading and I keep finding 2 common forumals for working out how close you can put seating to your screen or more importnantly whats the biggest screen you can put in
the 2 formuals I keep coming across are:
closest seat can be 1.5 x screen width
closest seat can be 2 x screen width
OK so which is correct or are there different views on this ?
I aslo came accross recommended THX viewing distance which seems closer than normal ?
thanks
thanks
