Rookie Sonotube help (1 Viewer)
Larry Noud
Grip
Hi,
I have a sonotube that is 41 inches tall and 24 inch diameter.I am thinking of getting the Audire Tempest and using a 6 inch diameter port at 22 inches long.I think I should be in the area of a tune of 17 HZ.What are your thoughts on this and do you have any suggestions.I will be using this mainly for hometheater.Thank you
Phoneman66
