matt steele
Grip
- Nov 19, 2003
Which 18" subwoofer is best for my application?
I have decided on getting one 18" woofer. Now the question is which one would be best?
Sound splinter RL-p 18" or
FI Q18"
I will be powering with a EP-2500 so there is lots of power.
I was thinking of doing the FI q18 BP power upgrade. Is this worth $60 to get some more power handling out of it? This is what the website says about the BP power option...
"This new option adds a machined aluminum compression plug to the pole which helps channel all of the air under the dustcap around the coil for better cooling. To aid with this increased airflow we also add 6 axial cooling channels in the top plate. Along with increased thermal capacity comes the addition of an extra spider and a changed spider pack.
All of these new features increase power handling from 200-500 Watts depending on the application."
I have at max 12.13 cuft worth of space to build a box. This space will be smaller when the port is added.
Which sub would work the best for me? What one would be best with the space that i have and the power i can give it? I want to tune the box really low 14-16 hz, would that be about right?
Maybe 11 cuft after port displacement isnt even enough for an 18" sub, im not sure. Would this be enough room?
FI Q18"
