World Wide Stereo
Questions about Flooring (1 Viewer)
JohnWyn
Anyone have experience with pergo (Or other hardwood type) flooring for a HT setup? Is it best to use carpet instead or just put a big rug on the floor? I'm currently revamping my theater and am considering changing out the floor. The walls are regular drywall, no sound material and I've got a 10' high ceiling. The room is fairly small too.
Dave Poehlman
You may want to check out Richard Clewer's beautiful HT. He's got a Pergo floor.
Any hard surface will lend itself to reflections, and, with a 10' ceiling, it could get pretty "echo-y" in there. You may need to throw down an area rug and maybe some wall treatments.
DonnyD
Some sound deadening on the floor is usually a good idea to reduce the echo effect caused by reflective surfaces. Being a remodeler, it always surprises me when we remove carpeting in a room and hear the difference in reflectivity of even us talking. Quite a difference!
If you do a hardwood or pergo type floor, just be prepared to add some area rugs too.....
Tim86
