JeremyR
I am debating on upgrading from my 5 year old Kenwood VR-507 to the new Onkyo 705. I have never used the Kenwood as a video pass through, as I've never needed it and have always been skeptical.
http://www.onkyousa.com/model.cfm?m=...s=Receiver&p=i
However, with the 705's Faroudja video processing, I'm debating on whether I can start and hook the Xbox 360 via component, my HDDVR via HDMI, and my 2 year old Sony progressive scan DVD player up to it, and send those sources all across HDMI to my television.
I do have a question, I know the receivers pass HDMI exactly through.. what comes in goes out. So the HDDVR will pass through exactly what it is sending.
And the Xbox 360, if it is set at 720P through component, will pass that through. If it's sent to 1080i, it will convert to 720p. Frankly, on my 32 inch Samsung HDTV I can't tell a difference between 720P and 1080i, probably because it's a smaller screen.
Will the 480P signal the DVD player is sending out be upconverted to 720P in the receiver to be sent to my TV? And if so, should I notice somewhat of an improvement?
thanks in advance...
