John Gido
- Jun 18, 2001
Just looking for some opinion/feedback on mounting a SMALL 20" flat panel monitor (weight approx 14lbs.) in our bedroom. I purchased a mounting bracket for mounting to a single stud (bracket weight is < 4lbs). The only problem is that the wall space available for mounting does not contain a stud in the correct location (center of the wall). It is a small section of wall space between a doorway and a closet approx. 24" across and, unfortunately, the only available space.
Would it be possible to use 2 "molly" screws (NOT plastic anchors) through the bracket & drywall. Total weight would be < 20lbs.
Thanks in advance.
Thanks in advance.
