Andy Kim
- Oct 4, 2000
Hi!
I primed my MDF boards with plain black spray paint and then sanded. I did this about 3 times for all my boards.
I then went to spray my first board with gloss black spray paint. It worked well.
So far so good....now the trouble.
For the next 4 boards, the gloss black spray paint would stick on the top of the boards BUT would ABSOLUTELY NOT bind with the 4 sides of the boards. I would spray the gloss black paint on the sides but about a minute later, the paint would all be gone as if I did not even paint it at all. The sides were dry to the touch in a matter of a minute. It just evaporated or drooled down. I don't understand why the paint won't stick to the sides. Its almost like the "oil in water" effect...the sides refuse to mix or absorb any paint.
I did wipe the boards down with a damp cloth after sanding but that was after atleast a coat of black primer paint. Could that have ruined it? And I don't understand why my first board worked but the rest of the 4 didn't. The only difference is that I sanded the 1st board in doors and the other 4 I sanded outside in below or near zero temps. Could the cold temperature have done something to it? I'm clueless!
I'm thinking of buying some gloss paint in a can (instead of spraypaint) and then rolling it on but I'm not sure whether the same thing will happen with roll on paint. Have I ruined the boards forever?
Any thoughts would be appreciated!
Andy
Andy
