pioneer vsx-520 no power (1 Viewer)
bjballar41
Brock
my cousin gave me this after he got another one said this one was messed up i took it just to see if i could fix it cheap its not getting any power at all. is there some kind of common problem on these thats an easy fix or should i chunk it and not even waste my time?
bjballar41
Brock
ill give that a shot its looking like it will be a lil more than i am capable of doing myself
TimmyBosko
Tim Bosko
Have you checked to see if there are any fuses and if so are they blown.. Just a thought..
TimmyBosko
Tim Bosko
There are many types of fuses with different looks.. the ones I am familiar with are the the standard type fuses.
They will look like a very small (1 " ish) glass tube with a silver looking cap on each end. There will be a wire inside the glasstube that connects to each end.
If those are what you see then look to see if the glass is nice and clear/clean and the filiment inside is intact. If that is the case then the fuze is likely good.
If the glass is black or darkened/discolored and the filiment in the middle is separated then that fuze is blown and requires replacement.
Not sure how old this receiver/amp is. If it is a newer model then the fuzes may look different and if so hopefully someone else can describe them to you.
Hope this helps..
bjballar41
Brock
It's with in a year. I did see one like u mention but looked ok. I'll look for more like that
Jason Charlton
Baltimore, MD
Jason Charlton
Even if you find a blown fuse, that's almost never the actual root problem. Fuses serve as a cheap point of failure to protect the rest of the equipment from a potentially catastrophic failure.
If you replace a blown fuse, and the new one blows again, then there's something else the matter that may be very difficult for laypeople to troubleshoot.
Poking around inside a receiver may also void your warranty, so be careful.
Sadly, most CE these days are cheaper to replace than to fix.
Nielmb
