Parts Express Bass Amp (1 Viewer)
Michael Gdwn
Parts Express says
"A built-in rumble filter reduces power robbing subsonic frequencies to protect the woofer and increase amplifier headroom. "
Does that mean that it will reduce the quality of low bass? And if it doesn't, what does it mean?
Michael
Tom Brennan
(see above)
Michael---The filter may, in some cases, increase the quality of the low bass. Bass reflex cabinets can suffer from runaway cone excursion if pushed hard below the frequency at which the enclosure no longer loads the cone, this can cause very audible distortion. A filter will gaurd against this. The filter will be of little or no benefit to sealed enclosures or reflex enclosures tuned very low. So it depends. I'd venture to say that for the average subwoofer using a 10-12" cone and reflex tuned to the high 20s-low 30s range it would help. I use this amp (I presume you mean the 300-794)driving four 15" JBLs and several friends use it too and all are very pleased with it.
www.chicagohornspeakerclub.org
Dustin B
That rumble filter is easily modified as well. All you have to do is swap out two resistors. I've got a bunch of pics up on my website doing this to the 300-792. You would do the same thing to the 300-794. Even tuned to 20hz or lower that rumble filter won't hurt anything and can be of benefit (on a select few DVDs anyway).
The second page of this PDF file explains what to do and what all the options are:
http://www.partsexpress.com/pdf/300-794.pdf
foster2292
