Keith_Hart
Grip
- Aug 11, 2003
New to this whole home theater stuff so I found this site trying to figure out what I am going to be doing. I inherited a very nice home theater system from a relative and I am not sure what I really have. I have an unfinished basement and I am planning on finishing it out and this system should fit in nicely. Again the only problem is that I have no idea what I have and I would like any suggestions on if the equipment is up to date and will work for what I need. Here is a consolidated list of items with questions. If you can tell me what I am missing so I can begin looking for it I would be very appreciative.
Projector – RUNCO it is a big CRT version but there are no markings on the unit to tell me what model of the CRT product it is. I have the serial numbers and have e-mailed RUNCO but have not heard anything back. The date on it is 2/99. Does anyone know where a model number or id might be on the unit. Also it has a Digital video processor separate unit. The question I have is can I use this projector like a TV? Also do I need to buy a separate item to make it show TV and movies in HDTV? Is it even capable of working like that.
Amps – I have two amps that are in the boxes. The first one is a Parasound PSP-1500 AV processor / pre-amplifier. Not sure what this is for but the next one is even bigger. The second item is a Parasound HCA High Current power Amplifier. Not sure what either of these two do but I assume that one helps push power to the speakers and the stereo.
JAMO Speakers – These things are very heavy speakers. I have 4 speakers that are about 3 feet long and very heavy. I can’t find any model type on these either. I have looked on the JAMO site but can’t find anything that matches. It also has a two-foot by one foot base box that goes with the system. In most of the post I have read everyone notes that you need six speakers for a quality sound. Should I be looking for other speakers if I am going to be putting this stuff in a big room?
Creston ST-DS remote. Believe it or not I can figure this one out. There are four separate items for this but they all appear to be in good shape.
Screen- This one I can just say I have a long screen about 10 feet that has an electronic motor. Have not played with this one but assume it is in good shape.
Overall I think that I am missing the main receiver and a good DVD player. Not sure why I did not get those also but I assume that these are needed to make the system work. Is there anything else that I am missing that I should begin looking for?
Thanks in advance for everyone’s help and I know there are a lot of questions. I just feel like a opportunity to set up a great system here but not sure what is needed.
Keith
Keith
