I Need to find a tech that will replace my green tube in my NEC XG 75 PJ. I'm in orange county NY ( about 1 hour from NYC ) Anyone know of a tech I can contact ?
I dont recommend you tackle a retube unless you know what you are doing, and have lots of experience under your belt with your NEC. If you do not, go to the CRT forum at AVS, and ask there, someone will be able to help you. Actually, in both cases go there, and they can help you.
