Need Recommendation: Progressive Scan DVD (1 Viewer)
Sheena
Looking for a good high quality prog scan DVD player. And (since I'm a girl) I want a pretty silver one :) ... I was thinking about the thin Philips one. But I need something that can play VCD's too... I have so many problems with my Sony. DOes anyone have any suggestions?
Lew Crippen
This thread is the latest of a series of threads that will help. You can try searches from that area (audio/video sources) if the one a I suggest is not of sufficient help.
Bill Kane
Sheena,
Lew's post is a good thread to read back and it brings up the issue that the Panasonic RP-62 and RP-82 WILL play VCD but NOT SVCD (which sounds to me like a format associated with digital cams -- is this what you want?)
In either case, both units are available in SILVER (and only silver for the RP-82 it seems for now).
bill
Geno
Sheena, I too was looking at the Philips, q50 I believe. I was looking at it for the same reason and NO I am not a girl, I just like cool looking things. But in the end, I settled on something less expensive, because budget.
I would almost call Crutchfield and talk to thier customer service and find a good dvd player, then go shop the best price.
Staff online
Sp2024
