Mars1560
- Nov 4, 2010
- Scott Marshall
Alright, here is my problem. My wife and I are moving into a house for the first time. We are renting it for a long time from someone, he is fixing it up. He was installing crown molding and wanted to know if we wanted surround sound. We said yes. We bought monster speaker wire from best buy, and he hid it behind the crown molding. It is a relatively big living room, the back speakers will be maybe 20-30 feet back. The problem is we are working with a limited budget and a credit card from best buy which means I am stuck to buying stuff from Best Buy and it should probably be around or under $350. I have been looking a lot at best buy but all the HTIB (home theaters in a box) with a DVD player or Blu-ray, have proprietary wiring, which I have heard is hard to hook standard cable wire up to. So I am wondering what options I have. Is it possible to have standard wire hooked to the proprietary wiring, if so how much is that and do I have to do that through the manufacturer. I am new to all of the terminology with this stuff, so if you could make it as basic as possible that would be great. I really appreciate any help anyone can offer. Thank you so much.
Scott
Scott
