Since Windows 8.1 will no longer be supported starting in January, I'm going to upgrade my decade old computer. How come desktops no longer come with optical drives? At least that's what I'm seeing in my initial browsing of new computers.
Because most software is now distributed digitally, even boxed - it'll be on a flash drive or just have a dl link, and the majority of people just don't use optical drives. You can sometimes customize a desktop to add one but it depends on the manufacturer and model. Most systems still come with at least one slot in the case so it can be added post-purchase if desired, but check for that first if it's necessary to do so. Be aware that some vendors/models now use "laptop" style drives (they work but always feel quite flimsy to me) rather than a true desktop model drive.Since Windows 8.1 will no longer be supported starting in January, I'm going to upgrade my decade old computer. How come desktops no longer come with optical drives? At least that's what I'm seeing in my initial browsing of new computers.
Why avoid Windows 11?I build my own so I get exactly what I want. When looking at a new pc you should stick with Windows 10 and for now avoid Windows 11.
What kind of processor is in your old machine?Since Windows 8.1 will no longer be supported starting in January, I'm going to upgrade my decade old computer.
It is still possible to get a free upgrade to Win 10 from Win 8.1. MS originally said it was a one-year offer but people find that you can still get the free update from the MS site. It may run slow depending on your processor.
I'll let Dave answer this question as I run Windows 11 on two of my machines without issue. Whatever you do, however, make sure the computer you buy is capable of running Windows 11 as it has some very specific hardware requirements. In particular, you need to have a current TPM.Why avoid Windows 11?
I’m not buying any computer that doesn’t have Windows 11 already loaded in it with the latest processor.I'll let Dave answer this question as I run Windows 11 on two of my machines without issue. Whatever you do, however, make sure the computer you buy is capable of running Windows 11 as it has some very specific hardware requirements. In particular, you need to have a current TPM.
Well, the "latest" processor is heavily dependent on what you plan to use the machine for but I hear you and agree.I’m not buying any computer that doesn’t have Windows 11 already loaded in it with the latest processor.
Yeah, I probably don’t need an optical drive any longer as I don’t use my drives on my current computer....to go back to your original question. Yeah, almost nothing comes with an optical drive anymore. For the most part they aren't needed, unless you're ripping or burning media. So if you need one, an external one is the way to go. I actually have a stack of four optical drives, because I used to rip a lot of stuff. I do recommend an enclosure that has a fan, which is very hard to find these days. Optical drives heat up pretty fast. I have a couple of the same enclosure that Scott posted. I've always bought the drive and enclosure separately. They're absurdly easy to install.
Because no one buys software on physical media anymore.How come desktops no longer come with optical drives? At least that's what I'm seeing in my initial browsing of new computers.
Yeah, I'll probably just play it safe and get another desktop and continue to use the same printer and monitor.IF you've never spent much/any time on a laptop before, you might hate switching to that at this point... although you could (likely) always still use it like a desktop w/ a regular monitor and mouse at your main location and only use it as a laptop elsewhere as needed...
_Man_
