Hello,
I have an audio question about my setup I'm hoping someone can help me with.
I had my Vizio (M55-C2) setup with a direct cable feed and an optical cable to my Vizio Sound bar (SB3821). I use optical between the TV and the Soundbar as the Soundbar only has Coax, Optical, and RCA for audio input. Everything worked great and all sound levels were just fine.
My cable company then forced me to use a cable box. I connected the cable box to the TV using an HDMI cable.
The problem is, the sound is terribly LOW when I watch cable TV. I have to turn the soundbar almost up to MAX volume to get decent levels of volume... Then if I switch to something like NetFlix or Amazon Prime (any of the built-in Vizio apps), the sound is absolutely BLASTING.
Why did adding the cable box screw with the audio for cable? No combination of settings I can find on the TV seem to help so I'm here looking for any advice.
Thanks!
//Brew
Thanks!
//Brew
