Jed M
- Oct 2, 2001
I have a Klipsch RC-3 II for sale. I am asking $200 shipped. This has been a favorite center for many Klipsch fans for years and would be a great way for somebody with a ref system to expand to 6.1. This has not been used for the last 8 months and it is in excellent condition with the exception of a small nick on the lower back. I can provide a picture for anyone who would like to see it but it is basically unnoticeable unless you are underneath and behind it. I do not have the original box, sorry. Here are the specs:
FREQUENCY RESPONSE:
62Hz-20kHz ±3dB
SENSITIVITY:
97dB @ 1watt/1meter
POWER HANDLING:
150 watts maximum continuous (400 watts peak)
NOMINAL IMPEDANCE:
8 ohms
ENCLOSURE TYPE:
Sealed
DRIVE COMPONENTS:
Two-way system using one 1" (2.54cm) magnetically shielded, titanium dome compression driver tweeter with a 6" (15.24cm) square 90° x 60° Tractrix® Horn and two 6.5" (16.5cm) magnetically shielded, aluminum cone woofers
TWEETER:
K-105-KV 1" (2.54cm) Titanium dome compression driver
HIGH FREQUENCY HORN:
6" square 90° x 60° Tractrix® Horn
HF CROSSOVER:
2100Hz
WOOFER:
Two K-1085-SV 6.5" (16.51cm) Cerametallic® cone / cast polymer frame
DIMENSIONS:
7.9" (20.1cm) x 22.9" (58.2cm) x 9" (22.8cm)
WEIGHT:
29 lbs. (13.18kg)
You can read more about it here:
http://www.klipsch.com/product/product.aspx?cid=412
Here is a link to its review on audioreview.com
http://www.audioreview.com/speakers/...5_2743crx.aspx
I accept paypal and money order. Feel free to contact me via pm or email if you don't want to post here. Thanks for looking.
FREQUENCY RESPONSE:
62Hz-20kHz ±3dB
SENSITIVITY:
97dB @ 1watt/1meter
POWER HANDLING:
NOMINAL IMPEDANCE:
8 ohms
ENCLOSURE TYPE:
Sealed
DRIVE COMPONENTS:
TWEETER:
HF CROSSOVER:
2100Hz
WOOFER:
DIMENSIONS:
WEIGHT:
29 lbs. (13.18kg)
