Ryan T
- Sep 10, 2001
Hey guys,
I know some of you have seen my previous post about speaker designs. Anyway I have just finished my project. I started desinging the satilites and subwoofer about 3 months ago. I finalized the crossover at 2,300 Hz. Its a Linkwitz 2nd order X-over and theres a 2.5 dB pad on the tweeter.
The dirvers i used for the satilites are Hi-Vi TN28 dome tweeter and the vifa 4.5" buyout woofer. The subwoofer is a 2 cu. ft (tuned to 27 Hz) 10" titanic 1000. The plate amp i picked was PE's new super budget amp. It has a whooping 25 watts RMS into 4 ohms . But the price was right and the loudest i'll be playing my comp system is around 90 dB or so.
Anyway the design uses 6" dia PVC pipe with MDF endcaps. I went with sealed enclosures instead of ported. I know it makes the F3 of the satilites 130~ Hz but the sub is gonna take over at that point. I could have ported them and lowered the F3 to around 70 Hz but I really wanted the smaller enclosure. The laminate is PE red maple .
The speakers sound GREAT! Much better than I tought they would. The only draw back is how much they are lacking in the bass departement. But with the subu I dont notice any problems.
Heres the picture of the system
Ryan
Ryan
