Jeremy M
- Apr 1, 2000
Hi,
This is more of a "feeling-out"/question post that I need some info to help sway me towards whether I want to start looking at HDTV sets or waiting until there get to be more and more HDTV broadcasts. But I am semi-seriously considering going "next generation" and investing in a very good 16:9 widescreen HDTV TV. (Yes, I know what I am looking for doesn't start below $4000, but to get the best, you gotta be willing to dish out the cash (usually), right?)
I guess what I want to know more than anything is, are OTA channels broadcasting in HDTV yet in Iowa, specifically eastern Iowa (Muscatine, 30 minutes south of the Quad Cities)? And if so, which ones? If not, can I still somehow find a way to receive them, other than by my DirecTV dish? I checked out that one guy's website that supposedly uses the troposphere(?) to get HDTV signals from almost 600 miles away?! I can't even pretend to begin to understand what he used or how he is doing it. But just seeing that and reading some posts on here, I have gathered (I think) that you can receive HDTV signals/broadcasts from other cities/other cable systems, most times using different antenna's of sorts from Radio Shack and other places, right?? And if that is possible, using antenna's to "snag" HDTV broadcasts, could I pull in Chicago or St. Louis or even Minneapolis/Twin Cities (or Milwaukee/Wisconsin) HDTV broadcasts with a powerful enough antenna? I wish this stuff made more sense to me.
I hope none of this confused you all too much. But the more I think about it, the more I really want to get an HDTV set, but then again, I don't want to go out and spend between $4000 and $5000, and then find out I have no way to truly utilize it. I am sure the local OTA channels will be going to HDTV over the next few years, but why go and get it now if I have to wait until then, if can only get local OTA channels to work with the TV?
Or maybe you all can give me some advice (especially if I won't be able to get HDTV broadcasts from where I'm at)... should I just wait until local OTA's broadcast in HDTV, or take the plunge anyway to enjoy DVDs and analog-TV at its best, so I will have it when HDTV becomes available to me/my area??
Great thanks in advance for any helpful info and/or advice.
Jeremy
Jeremy
