I am planning to change the surround speakers in my family room home theater (20x13x9, open in the back to the kitchen). Vurrently I have the the RS750 as my main and the RS500 as my center channel (bought from AV123.com). I have their ELT as my surround, but they are too big and bulky. I plan to replace them with 4 surround (2 at sides and 2 in the rear).
Since there is a 45 degree slope between my walls and the ceiling, it is very tricky to mount the surround speakers. So I am leaning towards in-wall speakers or if it is on wall, they need to be small and light. I would appreciate if any of you can suggest me the correct speakers for my surrounds. My budget for the surround is < $500.
Thanks for your help.
KaushikC
KaushikC
