Fred DeGrandis
- Mar 3, 2001
I am ready to buy an amp!!! I need a few recomendations
I have spent the last 3hrs tonight looking through the different posts, and archieves, for info about amps, and I am getting really sick of looking at the screen. Its 4:00 in the morning here, and I am tired. Ok, now to the relevance of this post:
I am ready to take the plunge and pick up an amp( 5 channel would be great, unless I am crazy for sugesting it on my budget). I have a Marantz SR7000 receiver(100x5) and a paradigm reference setup(Studio 80's, Studio 20's, and a Studio CC), with an Infinity 12, which I will be replacing with 2 count em 2 SVS 20-39CS, and the 700Sampson amp that SVS sells. My question is,
Awhile ago, in a smaller room than I am in now, the Marantz powered these no problem. Now, down in a big room(28x18x8ft) It doesn't quite cut it. I want to upgrade the amp, if I can expect an improvement in sound, and if the speakers will be louder at lower levels on the volume knob on the receiver.( I use to be able to listen to movies at -20db, and that was plenty loud, now -20db wont cut it) I am wrong for assuming that this is somthing adding a new amp will yield? My budget is around 1,000. give or take a little. I am looking for the best" Bang for the buck" route.
It also wouldnt hurt if this thing was so loud that it made my ears bleed
Now, after countless hours of lurking through posts, and research,
I have came up with several candidates.
In no particular order:
1. The Outlaw 750(I have read alot of good things, but have not eard from anyone who owns one).
2. Marantz Mono Blocks(Would using these yeild better results?)
3. The Marantz MM9000( dont know if this will do the trick though?)
4.Anthem MCA-5( I have read some nice things about this one)
5.Rotel RB-985mk2
6.
5.Rotel RB-985mk2
6.
