HT Experts In Houston??? (1 Viewer)
Robert_B
Are there any HT (Home Theater) experts or companies or consultants that service Houston??? If so can you make a recommendation? Also, can you recommend an ISF tech in Houston as well if the referral is different than above?
I need assistance with:
-TV Selection (Yes, I could do this myself...)
-Audio Amp/Spkr Selection
-HDTV Decoder Selection
-Wiring Issues (likely to involve sheetrock repair)
-ISF Calibration.
-And, many other issues...
Can you make a recommendation???
-robert
Burke Strickland
Robert -
There are a number of companies here in Houston that do some or all of the things you are looking for. A lot depends on how elaborate an installation you contemplate, what your budget is, and whether you want the installer to furnish the components or are assembling them yourself (ie, buying from several different sources).
Check your e-mail. I will be more specific there.
Burke
SuperMarty88
