I want to put my Verizon FIOS HD receiver (Motorola HD QIP 71001) on top of my Sony BDP S350. The FIOS receiver is pretty light, but it has a larger surface area than the Sony player. The Sony player is too small to support all "legs" of the FIOS receiver (in order to keep the FIOS receiver flat on top of it).
I found a small rectangular spacer to put in between the Sony player and the FIOS receiver. The spacer its almost as wide as the FIOS receiver, but smaller on the depth side. The legs of the FIOS receiver are not touching the spacer. I checked the bottom of the FIOS receiver, and it looks like the spacer is not covering the circulation holes (for heat release).
Is this an acceptable arrangement? I could not find anywhere the max weight the BDP 350 can support.
Thanks for your help!
JRod
JRod
