Joshua Makler
- May 7, 2015
- Josh
hey guys, I know what I want pretty much, but I dont know what Im doing here. My options are low-end, and my TV has optical out, but NOTHING i can afford has optical inputs, so thats just straight out of hte question.
im OK with RCA, but I dont know what I need -- devices like the logitech z506 are '3d stereo' and only use ONE stereo output with three outputs on the end, and im not sure if this would deliver true directional audio, or merely add speakers into the mix.
devices like the theatre solutions t509 use three separate audio outputs for each front, center and rear, and I believe this is superior to the z506 in that its ACTUALLY three separate channels, but i have no idea how this works on a technical level, so I dont know if its what I want.
I DEFINITELY want three separate channels that work to have say, REAL directional audio, not just more speakers -- and I dont know what other accessories I will need at all!
the two main setups I am looking at are -
ts509 - http://www.bestbuy.com/site/theater-solutions-theater-solutions-ts509-home-theater-5-1-speaker-system-multimedia-surround-new-black/1308782193.p?id=mp1308782193&skuId=1308782193
USB sound card - http://www.newegg.com/Product/Product.aspx?Item=N82E16829126101&cm_re=5.1_USB29-126-101Product
cables - http://www.newegg.com/Product/Product.aspx?Item=9SIA0PG06H5015&cm_re=3.5_to_RCA9SIA0PG06H5015Product
or
logitech z506 -http://www.newegg.com/Product/Product.aspx?Item=N82E16836121044
it LOOKS like I would not need extra cables -- I already have one 3.5mm-RCA L/R cable...
it also LOOKS like I would not need the external sound card for this -- that it would just plug-n-play with my existing headphone/line out jack on my PC/TV -- but I have NO IDEA if this is the same quality as the setup above
I also dont know if either set up will work, or what I am missing.
Please Help! I have the cash on hand, am ready to go buy in the morning, I just dont know what to do!!!
or
