lbk
- Apr 24, 2007
- Bob
Hello. I'm new to the forum and I have a few questions which arise because I'm having some audio problems. Any insight would really be appreciated.
Here is my setup:
I have a Harmon Kardon AVR 145 Receiver.
1. Cable Box to receiver - Component video, composite audio;
2. DVD to receiver - Component video, digital coaxial audio cable
3. Receiver to TV - Component Video
4. Speakers - JVC SX-XSW6000:
This system has a powered subwoofer: Frequency Response of 20-200Hz, Output Power 100 Watts, Crossover Frequency 200Hz
5 Satellite speakers: 2" x 3.5", Frequency response 200-20kHz, Power rating 110 Watts, Sensitivity 85DB, Nominal Impedance 8 Ohms
My problems:
A. Audio Volume Problem to the surround speakers: My dvd is connected with a digital audio cable. When I run the EZ Set procedure, the system seems to calibrate the sound appropriately. However, when it is finished, I have virtually no sound coming from the rear left and right surround speakers. The sound is very faint and you have put the speaker to your ear to even hear it. I tried to manually set the volume. I had to turn the rear left and right speakers to full volume via the OSD setup, and this still was not enough to accomplish appropriate surround sound. I tried several different surround modes, and the problem did not resolve. I have mainly been using Dolby 5 speaker mode. The receiver is registering that all speakers are receiving a Dolby digital signal.
B. Audio Volume generally via the digital coaxial cable: When I hook up the dvd audio via the digital cable, I cannot turn the volume up very high. It is loud enough to use, but it should certainly be louder. It is not loud enough for a super bowl party, for example. When I hook the unit up via a composite audio cable, the volume is much higher. Why is this happening? I really don't want to use a composite audio cable, if I can use a digital coaxial cable - correct me if I'm wrong, but you can only accomplish true Dolby digital sound via the digital cable.
Any insight would be appreciated. Thank you.
Here is my setup:
My problems:
