JasonBenway
- Jan 3, 2003
I've ran speaker wire before but never video cable.
My basement is getting finished and I want to get a projector. So I plan on running the wire before the drywall goes up.
I figure I can just get a reciever that will upconvert everything to conpontent so I only need to run conpontent from the wall to the projector. First where is the best place to get a 30-35 foot conpontent cable.
Second I'm concerned about the size of the hole I'm going to need to get all three ends though the studs.
Then how to I leave it, so I can get access after they drywall. With speaker wire I just buy electric boxes and leave wire wound up in it.
Thank you
jb
Thank you
jb
