Help me choose an amp for under $1000 (1 Viewer)
Joey_V
Help me choose an amp for under a $1000.
I have looked at some Outlaw offerings but I dont like the way the amp looks (I'm sure it sounds good though).
Right now I have an HK330 and I want an amp that can better power the LSi9 that I have.
I would like a 5 channel amp though.
Right now, the top dog in my list is the Rotel RMB-1075.
If you have any suggestions, please tell me the specific model and why.... THANKS!
Joey
EDIT:
Now thinking of going 2 channel. Recommend me a 2 channel amp, too, for the same budget ($1000 new or used).
Joey_V
OK... how about 2 channel amps?
ANYthing in the sub-$1000 (new or used) is fair game!
Recommend some to me! THANKS!
Joey_V
Krell KSA-50S ($1000)
http://cls.audiogon.com/cgi-bin/cls....ran&1127174014
- Pure Class A @ 50w/8ohm (down to 400w/1ohm WOW!).
- No caps in output path.
or
Krell KST-100 ($1000)
http://cls.audiogon.com/cgi-bin/cls....ran&1126843222
- 100w/8ohms (down to 800w/1ohm) via Class A input, Class A output until about half power, where it goes to B slowly.
How would something like the Parasound A21 Halo (same price used) @ 300w/8ohms compare??
Or the Rotel 1080?
I want a no-holds barred 2 channel amp for my LSi9... I dont want to upgrade for a while!
FeisalK
Joey_V
2 channel I'd go digital :)
CarverPro ZR1000, one of the ICEPower amps, or Flying Moles
The nuForce reference8 have created quite a storm but they are a bit over your budget
annefnlys01
