Help ! Advice on Mounting Bass Shakers (1 Viewer)
Sherri nevins
Sherri nevins
Hi ! Someone please advise me where I should place these on Aura bass shakers.
after going over the bottom of my recliner with a toothpick I narrowed it pretty much down to two options:
1. Run a half inch board ( kinda too tight for 1”) under the seat above the bars in the picture and mount the base shaker to it.
2. Each chair has an armrest connected to it . I could mount one inside the armrest but I’m not sure how it would shake because it would only be on the side of the chair.
and with the reclining mechanisms it truly impossible to mount it anywhere else
Thanks for your advice!
Nielmb
