f1nuts
- May 4, 2007
- jason cottee
deciding to sell off my toshiba xa2...only as i do not have a library of sd dvd, and not much dollar into hd dvds........i stumbled across a toshiba hd-a1 in the local thrift store for $8.00 !.......seems to run fine, and figure i would use it just for the hd movies i own for occasional veiwing.
the only problem i see with it , is i cannot get the firmware to update via the iso image method...have never had any problems updating the xa2.... but the a1 just says "notplay" in the display....
tried it with at least 5 burnt images on cd-r but just keep getting the same message...when i click initialize it just goes straight back to the set up menu also....otherwise plays the movies.....any ideas what the problem is ?
