Sami Kallio
- Jan 6, 2004
Strange behaviour from the H/K, it kept shutting off during "The Rundown" and I could repeat the shutdown by playing back the same scenes (kept shutting down on the same frames). Kept doing the same thing later on with Charlie's Angels 2. Wasn't because of high volume level (-20dB to -15dB) and the receiver wasn't running hot either (open space with nothing on top of it).
Calling OneCall today to return it, I got it less than 3 weeks ago. Should I try my luck with another 7200 or go with different manufacturer? What Denon would you recommend in the same pricerange, around $800.
