Hartlus
- Nov 28, 2012
- Steve
I need help. I'm not an audiophile but I can appreciate good sound. However, I am working with what I've got and I would like to get true 5.1 surround out of what I have. I have recently purchased a new TV and I'm having trouble figuring out how I should hook things up.
TV: Sceptre X409 HDTV
SPDIF out
antennae/cable in
VGA in
3.5mm stereo in
3 HDMI in
USB
Component + audio in
Composite in
RCA stereo out
Speakers: Logitech Z5300
3 3.5mm stereo input jacks
DSL DVR: Motorola VIP1216
HDMI
Component
Optical
Composite
Coax
Halo 4 Limited Edition XBox 360 (probably Xbox 360s)
Various display outputs including HDMI
Audio out through HDMI or optical
Wii
AV Multi out (Composite, Component, RCA audio)
Slim PS2
Multi out (composite, Component)
Optical
Netbook
3.5mm stereo out
Quote from the Sceptre TV manual: "The TV's SPDIF out for 5.1CH is ONLY used for antenna/cable connection. Any other incoming audio signal will be passed out of SPDIF in PCM format."
If I understand correctly, plugging an HDMI into the TV will only give me 2CH PCM out of the SPDIF. I thought that I would be able to plug everything into the TV and only have to deal with finding a way to to split the SPDIF signal into 5.1 analog channels for the speakers but now it seams that the SPDIF is going to be useless for me.
Another thing I should mention: The speakers have a slide switch for 2, 4, or 5.1 channels. I would like to be able to just leave the switch on 5.1.
I've only ever used these speakers with 2 channels and they sound okay but I wouldn't say great. That's okay with me. As long as they don't sound bad and I can get true 5.1 surround when it's available, I'm happy.
So, the question: What do I need to do here? I'm guessing for the video side I can just plug into all the TV inputs from the other components and on the audio I can run all of those to some sort of switch, adapter, or receiver. I know almost nothing about these things. I had to do research just to ask the question. And, I know you always love hearing this, I don't want to spend very much money. Maybe you could tell me what my options are from cheapest to highest.
Thank you for your time,
Hartlus Basterd
SPDIF out
antennae/cable in
VGA in
3.5mm stereo in
3 HDMI in
USB
Composite in
RCA stereo out
HDMI
Component
Optical
Composite
Coax
Wii
Slim PS2
Optical
Netbook
3.5mm stereo out
Hartlus Basterd
