FS: Marantz SR-8200 THX AV Receiver (1 Viewer)
Al Roeth
Marantz SR8200 THX Select 6.1 AV Receiver - $750 plus shipping
I bought this unit about 3 years ago, and it has been operated in a clean smoke-free environment, and lightly used. It is in pristine shape, and includes the LCD backlit learning RC3200 remote, which itself is a $200+ value. The SR8200 sold originally for about $1700, and is THX Select certified.
The remote shows some minor wear, with some nearly imperceptable scratches on the back, but is not damaged or blemished, nor shows any wear on the front. I would rate both the remote and receiver a 9/10.
We've really enjoyed this receiver, but are moving cross-country, and are liquidating our entire AV system.
All original packaging, documentation, and box is included.
Basic specs:
Power Output: 120Wpc into 8 ohms, six channels continuously driven 20Hz–20kHz
Number of channels: Six
Surround-decoding formats: Dolby Digital, THX Surround EX, DTS-ES (matrix and discrete), DTS Neo:6, Dolby Pro Logic II, Circle Surround 5.1, multiple generic formats
Video Inputs: Five S-video and five composite; two component.
Audio Inputs: Eight line-level analog, 7.1-channel input; three coax digital and three optical digital
Dimensions: 17 5/16" x 7.25" x 18 7/8"
Weight: 42.5 lbs.
This is black North American model.
Although the unit has been surpassed 'numerically' by Marantz's recent model numbers, many feel that these 8x00 models from just a few years ago are actually stronger audio performers than the recent models. I can attest that this unit has excellent sonic qualities, is comparable with some of the best separates in music reproduction, and it's surround performance is top-notch as well.
For more info please see:
The Perfect Vision SR8200 Review
$750 plus shipping
Local pickup in the San Francisco Bay Area is fine as well.
Please contact via email.
Cheers
al
[email protected]
Detailed Specifications
FEATURES
* THX Select®, THX Surround EX®, Dolby Digital®, DTS ES® (Discrete 6.1, Matrix 6.1, Neo: 6)
* Dolby Pro Logic II® (Movie, Music)
* Circle Surround 5.1®(Movie, Music)
* 6 x 120 Watts (8 Ohm), Discrete Amplifiers
* High Power Current Feedback Circuitry
* Massive Energy Power Supply, Huge EI
* Transformer, Large ELCO’s
* 192/24 bit Crystal DAC® for all 6 Channels
* 2 24 bit Digital Surround Processing Chipsets
* ADDC (Adaptive Double Differential Control)
* Video Off Mode
* Large Heavy Duty Banana Type Speaker
* Terminals for all Channels
* RS232C Terminal for Future Upgrades or
* System Control
* Set Up Menu Via Composite, S-Video and
* Component Video Output
* Auto Input Signal Detection
* Improved Station Name Input Method, 50 Presets
* Auto Adjust Function for Speaker Distance
* Settings (Delay Time)
* Front Optical Aux Input (Digital Camera, Portable DVD)
* Large Multi Operation Left Dial Knob
* 2 Assignable DC Trigger Outputs
* __________________________________________________ __________
* RC3200 Programmable Touch-Screen, 2-Way, Learning Remote Control
* Pre-Programmed to Operate Marantz Audio & Video Products
* Controllable Display Contrast
* 1 MB Non-Volatile Flash Memory
* RS232C Computer Connection
* 12 Back-Lit Direct Access Buttons
* Macro, Beep, Timer
* Marantz Digital Learning
* Charcoal Grey, Silver Finish
INPUT/OUTPUTS
* VIDEO
* Composite In: 6 (DVD, DSS, TV, VCR1, VCR2/DVD-R, AUX)
* Composite Out: 2 + 2 (monitor)
* S-Video In: 6 (DVD, DSS, TV, VCR1, VCR2/DVD-R, AUX)
* S-Video Out: 2 + 2 (monitor)
* Component In: 2 (DSS, DVD)
* Component Out: 1 (monitor)
* Other Pre-Amplifier Out: 7.1 Channels (F, C, R, S, SB, SW)
* Multi-Channel In: 7.1 Channels (F, C, R, S, SB, SW)
* Multi-Room Audio Out: 1 (RCA)
* Multi-Room Video Out: 1 (Composite)
* RS232C: 1
* DC Triggers: 2 (Assignable)
* AUDIO
* Analog In: 8 (CD, TAPE, CD-R/MD, DVD,DSS, TV, VCR1, VCR/DVD-R)
* Analog Out: 4 (TAPE, CD-R/MD, VCR1, VCR-2/DVD-R)
* Digital In: 7 (6 assignable)
* Digital Optical In: 3
* Digital Optical Out: 1
* Digital Coaxial In: 3
* OTHER
* Pre-Amplifier Out: 7.1 Channels (F,C, R, S, SB, SW)
* Multi-Channel In: 7.1 Channels (F. C, R, S, SB, SW)
* Multi-Room Video Out: (Composite)
* RS232C: 1
* Speaker Terminal 6 Channels
* Multi-Room Speaker Terminal 2 Channels
* D-Bus RMC Out 1 (I/O)
* Multi-Room RMC 1 (I/O)
* External IR 1 (I/O)
* AC Outlets 1/1 Switched/Un-Switched
* FM Antenna 1 (75 Ohm)
* AM Antenna 1 (Ground)
* Front Inputs 4 (Audio, Composite, S-Video, Optical Digital)
* Headphone Out 1
SPECIFICATIONS
* AUDIO SECTION
* Power Output (8 Ohm): 120 W x 6, (< 0.05%, THD, 20Hz – 20kHz)
* Signal to Noise: 106 dB
* Frequency Response: 8Hz – 70kHz (+/- 3 dB), (Analog In, Source Direct)
* Frequency Response: 8Hz – 45kHz (+/- 3 dB), (Digital In, 96kHz PCM)
* Input Sensitivity: 350 mV/47 K
* TUNER SECTION FM
* Frequency Range: 87.5 – 108.0
* Signal to Noise Ratio Mono/Stereo: 76/72 dB
* Distortion Mono/Stereo: 0.2/0.3%
* Channel Selectivity: +/- 300kHz 60 dB
* Usable Sensitivity: 16.4 dBf
* Channel Separation 1 kHz, 45 dB (Stereo)
* TUNER SECTION AM
* Frequency Range: 520 – 1710kHz
* Signal to Noise Ratio: dB 50 dB
* Distortion Mono/Stereo: 1kHz, 30%, Mod. 0.5%
* Channel Selectivity: +/- 20kHz 70 dB
GENERAL
* Color: Black
* Front Panel: Metal
* Remote Control: RC3200, RS232C Cable Included
* Power Requirement: 120V, 60 Hz, 400 Watts
* Dimensions (Inch, W x H x D): 17 5/16 " x 7 1/4 " x 8 7/8"
foster2292
