langer61
- Apr 2, 2008
- jason
The daunting task of planning a home theater that will be in a basement has begun. I have to design a room that meets my desire for a home theater, is livable for my wife, and can be used for entertaining (i.e. the big game parties). I made the trip to my usual home theater store to begin looking at plasma screens and was turned onto front projectors by the salesman.
I currently have a makeshift "home theater" in my living room and much of the equipment will make the move to the basement. Right now I have a Rotel RSX1067 surround sound pros/amp and Definitive Tech. bipolar speakers in a 5.1 set up with a Pioneer elite plasma. I have been more than satisfied with the performance to this point but having been bit by the bug (again) and want to upgrade/improve upon my current situation. All of the audio equip will go to the basement and the plasma will remain upstairs for regular TV viewing.
Now the question...Front projector or Plasma for the basement? I have a low ceiling (7'8") with about a 15'6" X 17' area designated for the theater area. Strict enclosure area or a true home theater are unfortunately out of the question.
Front projectors are a new endeavor for me and I am not very well versed with their ins and outs, with the exception of some commonly discussed issues. I can reduce a significant amount of ambient light in the viewing area via strategically located can lights but the room will need to be lit majority of the time it is in use except during movies.
I am considering the Sony VPL-VW60 front projector with a screen in the 86-92 inch range or a 60" plasma. Here's the catch...there is duct work that will be soffited either parallel with the projected image all the way to the screen or perpendicular to it between the projector and the screen. My concern is; will the soffit (will only paint it flat/matte off-white) reflect or create brightness issues and degrade picture quality from the projector? Bottom line is cost is basically equal and the only hang up is will the projector provide a bright enough image for watching sporting events with some moderate ambient light surrounding the viewing area or will the plasma be a generally better picture in all lighting situations?
To sneak a second question in...upgrade to an HDMI compatible audio receiver (will be adding Blu-Ray that will have a dedicated cable to whichever video display) or simply use the pcm connection that I currently have?
Sorry for being long winded but this has been the best website I have found to bounce these question around without a salesman looking for a big sale!
