Matthew Will
- Jan 6, 2002
Alright, I'm building my first DIY speakers. They're a pair of Adire Audio HE10.1's. Here are a few questions that for some reason I just can't find.
1. Polyfill - Stuff it everywhere in the enclosure except near the speakers? Should I do anything to hold the stuff back so it doesnt shift and end up in the driver? Im building the recommended sealed enclosure so I'm not glueing it to the walls like you would in ported boxes.
2. I just glue the sides to each other with no screws? It seems like screws would split the 3/4" MDF I'm using. So I just glue it, clamp it, dry it, then caulk it?
3. How am I going to wire these speakers to my Sony Stereo Receiver? Each enclosure will have dual input terminals. Terminals for the tweeter and terminals for the 10" driver. I'm just burnt out. I'll probably figure it out eventually but any help is appreciated. Thanks. Matt
