Tim Johnson
- Feb 19, 2000
I just recently made the jump to DVD-A and I am having a problem with one of the discs I bought. I thought maybe one of you guys had run into the same problem.
The disk is Dvorak: Symphony #9 on the TelDec label.
Player: Toshiba SD4900
The disc packaging states that there is both a 5.1 and a stereo mix in "Advanced Resolution" However, when I put the disc in my player and attempt to play it I am only able to play the 5.1 mix. Hitting the "Audio" button on my remote does nothing (it swtiches between 2.0 and 5.1 on other discs) and I am not able to find a menu option anywhere to switch to the 2.0 track. Is this an incompatibility with my player on this disc or is the packaging just incorrect, OR am I just stupid?
