DVD on computer monitor (1 Viewer)
ChrisBoyde
Ok my computer monitor supports a max of 1600x1200 and I belive 480p is quite lower than that (isn't 720p lower too)? So If I can run this res can I get HDDVD on my computer monitor with my dvd-rom?
Scott L
No because:
1) HD-DVD isn't out yet and may not come out at all (blu-ray instead)
2) If the DVD Forum does decide on a standard for the "HD-DVD" it will probably use blue-laser, meaning you'd have to buy a new HD-DVD-ROM.
But your monitor can technically display all of 1080p when a new format comes out.
JamesHl
No. But that Terminator 2 extreme edition has a thing where you can watch the movie in 1080 with wmp 9. But apparently your computer has to be pretty fast.
RobertR
Quote from an AVS thread on the T2 WM version:
Brian it has been repeatedly stated that the resolutions is 1440x816p anamoprhiclly encoded to provide a 1920x816p output...
As this is a 2.35 film that is equal to a letterboxed 1920x1080p source if it was on a 16:9 screen.
ChrisBoyde
I didn't mean the new HDDVD format sorry I'll try to be more clear. What I meant was can my computer monitor act as a HDTV (I mean it's capable of a res over 720p). So why can't I watch my DVD's on my computer in 720p or 480p like if I had a HDTV and a progressive scan dvd player?
Oh and I did download the 720p version of the T2 extreme trailer from http://windowsmedia.com/9series/Demo...deoQuality.asp
it plays fine on my comp even with my older Radeon 7000.
RobertR
It should be able to without a problem. You'd have to have a compatible input (the HDTV device would have to output a VGA compatible signal, which is the type of input monitors have).
Rob Gardiner
Chris, I think I understand exactly what you're asking.
YES, when you play DVDs on your PC, hooked up to a 1600 x 1200 monitor, the DVD image will be scaled to your selected resolution. This provides a much more film-like image. At 800 x 600 and below you can still clearly see the gaps between the scan lines, but once you hit 1024 x 768 and above, the scan lines blend together into a smooth, silky image. :D
My favorite demo bit for this phenomenon is the FOX logo on the Cleopatra disc. Play this disc with PowerDVD and pause the logo. Switch between 640 x 680 and your max resolution. Notice how the top of the "0" in 20 looks like a bunch of horizontal line segments stacked on top of one another at 640 x 480, but looks completely solid at hi-res.
Enjoy! :D
Jonathan Burk
Castaic, CA
Jonathan Burk
Yes, generally speaking, just add a "P" to the second number of a resolution to get the equivilant DVD/HD resolution.
Thus, 1600x1200 would equal 1200P! It's amazing to think that everyone already has "HDTV's" sitting on top of their desks.
Gigaspin88
