DIY speaker cables (1 Viewer)
Kevin. W
I'm looking at making my own speakers cable using Cat5. Question. Is all Cat5 the same? I site that talks about the DIY cables uses Belden Cat5, yet I can't find a supplier in the area. Any input would be appreciated.
Kevin
Chu Gai
there are teflon versions available. the idea is to try and minimize the capacitance a bit which you'll get during the braiding process.
Shion_ca
IF you want to talk to someone very knowledgable about DIY cables and who stocks all the RCA connectors, Belden cables, sheilds and insulators you could desire, I recommend take five audio canada. Give this site a look and tell me if it works out for you. Best of luck
http://www.takefiveaudio.com/
*Note am in no way affiliated with said site
SuperMarty88
